03-04-2025 17:50 PM
I’ve just joined smarty and took out the unlimited broadband plan at £20. It is now saying 2 weeks in that I’ve used my data 39gb. How can this be if it’s meant to be an unlimited plan?
04-04-2025 09:45 AM
@DeniseC_3224043 Just a heads up - it is unlimited mobile data and not broadband. It may not be as reliable as true broadband and that is why Smarty say that you should not rely on it as a replacement.
I agree with @SmartyTrousers in that it ismost likely telling you what you have used thus far.
04-04-2025 08:59 AM
@DeniseC_3224043 By the sound of it, it’s just telling you that you’ve used 39GB of data so far, which is totally fine, as you are allowed to use an unlimited amount. There is no issue.
06-04-2025 22:51 PM
Hi. The plan looks like it’s changed in my account now but still to check if it’s still working. It did say 40gb but now says unlimited so looks like they’ve changed it
07-04-2025 15:11 PM
You're currently on unlimited data only.
We haven't made any changes to your account. Just a heads up, tariff changes take effect at the next renewal, so they won't happen immediately.
It looks like you're seeing how much data you've used.
