UK to Europe issue
JohnSpr_1051926
Smarty SIM Worked great for a mobile WiFi hub in the motorhome in UK. On trip to Europe msg on iPhone says โ€˜no internetโ€™. Wife & myself both have iPhones with O2 so data roaming charges are the same as in the UK. Any clues how we get the HUAWEI/Smarty SIM combination working please?
JJP2RidesAgain
Yes, you need to change the APN in your device to โ€œmob.asm.netโ€
https://help.smarty.co.uk/en/articles/2045756-setting-up-your-phone-to-work-abroad
* The above instructions apply to any device, not just phones.
Read the manual for your specific device on how to do this, or Google it, if you donโ€™t have the manual available.
5 REPLIES 5
JJP2RidesAgain
Sorry Iโ€™m not quite there yet. Made all those changes. Then msg on Huwei to use menu to turn on data roaming  which I did too. Huwei gets a tick as my network, however when I try Safari I get msg โ€˜No internetโ€™ . What am I missing? Or is this because Iโ€™m in Germanyโ€™s Black Forest? ๐Ÿค”
@JohnSpr_1051926 You will need to be certain that you are connected to a local mobile network. Can you see if there are local networks by referring to a mobile phone?
Thank you very much. I thought it was something along those lines. This provides clarity!! ๐Ÿ˜Š
Youโ€™re welcome - Thanks for the feedback, as all too often, no feedback is given to answers to questions on this forum, so people donโ€™t know whether their suggestions have worked, so appreciate your reply.
*** By the way, the APN change is a one time change - You can leave it as โ€œmob.asm.netโ€, as your device will work just fine here in the UK with that APN.
