10-09-2023 13:54 PM
Having trouble with data can’t use satnav without Wi-Fi sways have in the pass while I’ve been abroad. I’m in Spain now & need to use satnav?
10-09-2023 14:52 PM
How long have you been in Spain?
This could have a bearing on data usage. Have you been using your satnav while in Spain?
Smarty have an upto 12GB data usage limit of your normal plan. You may have already reached this.
Alternatively, I think there is the option to purchase data packages for use when abroad. I'm not sure of how cost effective this is compared to using a Spanish SIM with data
10-09-2023 15:10 PM
Does your phone support an eSIM?
If so, consider https://www.frewie.com/ . This eSIM provider covers Spain, and has just been highlighted to the Smarty Community by @JJP2
10-09-2023 15:33 PM
Good afternoon! 🖐
Please review your data usage to ensure you have not exceeded your 12GB fair use limit. However, as with all service providers, we cannot guarantee 100% coverage when you're abroad. There can be various reasons for connectivity issues, and unfortunately, since you connect to a different network, SMARTY has no control over it, and we wouldn't have access to that network's information.
We understand that experiencing network issues is far from ideal and can be very frustrating, especially in today's world. You do have the option to manually change the network you connect to in your device settings, which may be worth trying. Additionally, you can attempt some standard troubleshooting steps to address the issue:
In the worst-case scenario, if you do not experience any improvement, you might need to consider purchasing a local sim card.
