MartinS_2296164's avatar
MartinS_2296164
Solved
Setting up Smarty for Guernsey
Hi, read some of the posts re using Smarty in Guernsey but still a bit confused!  Going for 4 days and I understand that I need to : 1. Change phone settings (do I need to change them back when I ha...
    MartinS_2296164  Let's deal with your points:
    1. No need to change settings back when you return.
    2. Incoming calls are not charged - see Price Guide p20. Emails do use a bit of data - depends upon size of email andante attachments could be larger (up to a few Mb)
    Any credit not used can go towards your next regular Smarty plan, so it's not lost.
