20-07-2023 11:50 AM - edited 20-07-2023 11:56 AM
Do calls between two SMARTY phones holidaying in Greece cost the same as two SMARTY phones at home in the UK?
20-07-2023 12:16 PM - edited 20-07-2023 12:22 PM
Yes, they will.
Also, don’t forget that within the EU, you have a data allowance of up to 12 GB, depending on your chosen Smarty plan, and WhatsApp, Telegram and Signal allow you to make and take voice and video calls, in addition to sending messages. (Obviously video calls will use much more data than just voice calls)
20-07-2023 14:36 PM
Thanks JJP2 😃
20-07-2023 15:23 PM
You’re welcome. 👍
That’s what we are here for.
20-07-2023 13:44 PM
@SIx Yep! Both are roaming but effectively being treated as if they were at home (but with a 12Gb data limit)
20-07-2023 14:37 PM
Thanks MSF 😃
