27-08-2023 19:06 PM
27-08-2023 22:29 PM
Not much to go, but I guess you mean you can’t enter radio competitions by text.
That’s because Smarty doesn’t support sending texts to the usually five digit short codes used for such competitions.
28-08-2023 09:18 AM
@ToddTho_1203828 I am guessing that you want to enter a competition and it requires you to send a text to a 5 digit number. currently you cannot do that on smarty as they do not support the process. If you could, it would be a chargeable text and require credit added to your account.
