21-02-2025SMARTY Community Manager
Yes, we heard you loud and clear—it’s been a long time coming, but the wait is finally over...SMARTY now supports shortcode messaging.
So, what’s the big deal with shortcodes?
They’...
ToddTho_1203828
27-08-2023SMARTY Pioneer
- MSF28-08-2023SMARTY Guru
ToddTho_1203828 I am guessing that you want to enter a competition and it requires you to send a text to a 5 digit number. currently you cannot do that on smarty as they do not support the process. If you could, it would be a chargeable text and require credit added to your account.
- JJP227-08-2023SMARTY Pro-coach
Not much to go, but I guess you mean you can’t enter radio competitions by text.
That’s because Smarty doesn’t support sending texts to the usually five digit short codes used for such competitions.
