Puk code
AdamWat_2186992
Puk code please
Strandloper
Hi,
We are the Smarty community here, users of Smarty, just like you.
I think you need to contact a Smarty Agent (see link below). They should be able to help with PUK and/or  Pac codes
12 REPLIES 12
Christo_1409829
Puk code
Ephraim_1033765
puk code for my phone please
I need 8 digit PUK code
ErikaTot_863915
can you please
puk code
@ErikaTot_863915  This is the community forum and there are no Smarty staff here regularly.
Please read this article for help:  https://help.smarty.co.uk/en/articles/1159752-getting-and-using-a-puk-code
Also, PLEASE NEVER post your personal information on a public website like this - for your own security.
@Strandloper is spot on, you need to contact Smarty directly.
For security reasons, PUK codes are unique to each user / each phone number, so it would not be a good idea to make either your phone number or PUK code public.
Strandloper
Hi,
cant get puk code, smarty agents invisible
@Santiag_1582902  Firstly, are you sure that it's a PUK code you need to unlock your sim? This would happen after you enter the wrong PIN code too many times. Please see : https://help.smarty.co.uk/en/articles/1159752-getting-and-using-a-puk-code
The only way to get a PUK code is via the agents and so you may need to be patient until they answer.
