09-02-2025 10:23 AM
I need to reset my PUK code
09-02-2025 14:34 PM
Enter an incorrect PUK 10 times and the SIM is permanently locked and cannot be unlocked. Basically, you cannot reset a PUK code.
09-02-2025 10:34 AM
@RobertR_1616224 That is all covered in this article: https://help.smarty.co.uk/en/articles/1159752-getting-and-using-a-puk-code
As it says, do make sure you are asking for the correct type of code first though.
