โ06-05-2025 08:18 AM
I have a data only sim and keepgetting the message Connected no WiFi but the data keeps getting used.
โ06-05-2025 09:20 AM
@JeanHar_1207578 Not quite clear what you mean here.
The mobile signal will be using data. Wifi normally refers to your phone connecting to a wifi network where you are.
Are you able to use data on the phone?
โ06-05-2025 09:40 AM
The message is actually connected with no Internet. The sim is in a router not a phone.
โ06-05-2025 10:23 AM
@JeanHar_1207578 So, the router is picking up signal and checking itself using data, but it is not creating a wifi network locally for your other devices to connect to?
Have you checked the Settings?
