Russell_1038153
09-06-2023SMARTY Pioneer
Motorhome wifi smarty sim not working abroad
Deborah_2537670
12-06-2024SMARTY Pioneer
All settings on APN are correct? Still can't connect? All lights are on the router?
13-06-2024SMARTY Guru
Deborah_2537670 It may be that there is no signal available where you are. Also, inside a motorhome, this is potentially a Faraday cage which insulates against all electromagnetic waves - sometimes solved with an external aerial to the router.
