โ10-14-2023 12:42 PM
I already made a post about this but it seems to have been deleted or something (I can see I've made 1 post but cannot get to it).
Does anyone have a line issue with call centres? Whenever I call a company number my line breaks up for them (I can hear them fine and if I manage to get them to call me back the line is perfect). It's like when I start talking (for example giving a reference number) the first second or two doesn't go through.
I've brought this up with Smarty support a couple of times and they say it isn't an issue at their end but I've had this problem with three different phones (all Samsung) and I've switched to a new SIM card multiple times hoping it would fix the problem.
As much as I love the package I have with Smarty I think I'll need to go to another provider due to this issue, my partner is also on Smarty and she never has any of these issues.
โ10-14-2023 01:37 PM
I would check that your device is 4G-VoLTE compatible, here is a help article to help you do this https://help.smarty.co.uk/en/articles/6142278-switching-off-3g
โ10-15-2023 09:18 PM - edited โ10-15-2023 09:23 PM
No, never an issue for me.
You have this problem, but your girlfriend doesnโt ?
Do you know whether the call centres you are calling are based overseas ? Even if you are calling a UK number, your call may be being routed overseas, which could be causing your issue. Does your girlfriend ring the same companiesโ call centres ?
Also, as @Rebekah_150 says, your phone(s) may not be 4G VOLTE compatible ? Are they old Samsungโs or relatively new ?
If you have tried multiple SIM cards, but continue to experience the same issue, itโs unlikely to be a SIM card issue, itโs more likely the phones you are using not being 4G VOLTE compatible and / or the fact that you are ringing overseas call centres with a low bandwidth connection, hence the calls continually dropping.
โ10-17-2023 12:24 AM
Thanks for the replies, I've got an S23 (5G) and previously an A52s 5G, in fact I'm pretty sure these issues started happening after switching to 5G handsets so maybe that's got something to do with it.
I've got WiFi calling enabled, my home internet is WiFi 6 and high bandwidth. The phone has a setting for VoLTE Calls Homes (Use LTE data networks for calls whenever possible). I'll try turning this option off see if it makes a difference.
My partner's phone is an old iPhone so doesn't have any 5G etc.
โ07-29-2024 02:00 PM
This happens to me evertime i call a call centre. Infuriating
โ07-29-2024 02:28 PM
@Terence_2445888 Did you read the preceding posts s they suggest possible causes?
โ09-04-2024 04:18 PM
I get this with every call centre but every other number works fine and was always fine with previous networks. Phone is a new Samsung S23 Ultra
Thanks
โ09-04-2024 04:44 PM
@RobinFe As has been stated already, this may be down to most of those numbers working via internet services rather than being standard landlines. I have experienced it before - on one occasion, I could not get through at all until the following day when it connected perfectly.
โ09-05-2024 06:11 PM
As already mentioned this happens every single time (not just one day and then is corrected) and only with this network so far. Would be great to have a reason why (this is only affecting this network) or a solution please. Thanks
โ09-05-2024 07:37 PM
@RobinFe We are only forum members like you and so do not have either reasons or solutions I'm afraid.
โ09-05-2024 08:33 AM
I moved to a different network in the end, never had a problem since.
โ09-05-2024 08:37 AM
@LappyGB Temporary problem or is new network better? Guess you'll never find out now.
โ09-05-2024 08:45 AM
I was with Smarty for about 18 months and could never get the issue resolved, moment I switched to a new network I never had a problem.
