Is it possible to hold two numbers on sparatecdevices? Carphone and handset?
RobertG_1942678
2 ACCEPTED SOLUTIONS
You can have two separate sims - different number on each - and join them as a group to get 10% discount.
Hello @JaneWat_2025639 . Firstly, as @Chalkychap and I both say (but still worth repeating), you cannot hold two sims with the same number.
To form a group with two sims please see: https://help.smarty.co.uk/en/articles/3406401-how-do-i-start-a-group You should find all the info there. Good luck!
4 REPLIES 4
Only if the number for the car-phone, and the number for the handset are different @RobertG_1942678.
How can I do this? Thanks
