05-25-2024 02:23 AM - edited 05-25-2024 02:35 AM
There are a LOT of customers posting in the Community that are having problems making/receiving calls on their device even though it has the 'capablility' of connecting to VoLTE/4G Calling and WiFi Calling.
Even if your device is on the SMARTY 'Approved Phones' list (or not) this may not be down to SMARTY supporting your phone BUT because of something you may not know about.
What many people do NOT know, is that when a mobile phone is sold by a 'Network' it is controlled by them with regards to software/firmware updates that will enable certain features to be available on your phone (even when 'update software' is performed on the device).
I recently got a 'hand-me-down' Samsung Galaxy J4+ phone from my sister that had VoLTE and WiFI Calling ability (among many other features) available to use but they could NOT be accessed on the SMARTY or iD network.
After much research I found iD Mobile supported my phone and yet when I changed over to their network I was still was unable to access these features (VoLTE/WiFi Calling) on my device.
What I didn't know is that all phones are controlled by the 'Network' that it was originally sold by and it had their firmware enbedded in to the device
For example. the firmware on my SG J4+ was:- SAOMC_SM-J415FN_OVF_VOD_PP_0015 / 40009a7d / VOD/VOD/VOD which shows that the firmware on my phone was controlled by Vodafone (VOD) which was the network that my sister was a customer of and had purchased the phone from.
(This information can be found in the phone under 'Software Information').
Unless I was 'connected to/used' the Vodafone network with this phone I wasn't able to get the firmware updates to enable all the capabilities available.
The ONLY way to 'free' a device for updates, so that it can be used with ALL networks, was to 'FLASH' the phone to an Unbranded firmware.
After Flashing my phone this is the software that is now on my device:-
SAOMC_SM-J415FN_OXM_XEU_PP_0013 / 40009a7d / XEU/XEU/VOD (XEU is 'unbranded').
I now have ALL the capabilities that this phone has with the capacity to use VoLTE, WiFi Calling etc.
These are the codes to which your phone network is locked in to:-
BTU (unbranded)
EVR (EE)
BTC, CPW (Carphone Warehouse)
H3G, O2I, O2U (O2)
ORA (Orange)
TMU (T-Mobile)
TSC, VIR, VOD (Vodafone)
XEU (EE & Three)
If you go down the 'Flashing' route... PLEASE do your research! It is easy to do once you know how but there are many things you need to know to do it safely!
SO, the conclusion of this is that this isn't just a 'network provider' problem i.e. unsupported phone, but could most likely be a firmware problem/restriction.
IF, you decide to 'FLASH' a device then PLEASE do your research! There are many 'small' details to take in to account but once you have all the info it is straight forward and easy to do!
Good luck all and I hope this helps solve a problem that affects so many!
10-01-2024 12:00 PM
Many thanks for your info. Much appreciated, but where start with further research? Anyway thanks again.
