โ05-11-2024 20:34 PM
Iโm currently using my iPhone 15 abroad and it can only hold an E signal and not the 4G signal that my wifeโs phone is using. There is a strong 4G signal where we are staying. Any ideas to what needs updating?
โ07-11-2024 08:45 AM
For anyone else getting the same problem, a workaround whilst roaming was to fix the phone on 4G via Settings - Mobile Services - Mobile data options - Voice and Data - 4G
This holds the 4G signal and the phone doesnโt drop to E anymore. Just need to remember to set back to 5G Auto when returning home.
โ06-11-2024 08:28 AM
@KB0703 Are you on the same network as your wife? Worth changing settings to manual network election rather than automatic and finding the best one available.
โ07-11-2024 08:41 AM
Thanks for the reply. My wifeโs phone is also roaming and picks up the same carrier. Her iPhone SE holds the 4G signal.
i have found a workaround and that is to fix my phone to a 4G setting in the โVoice and Dataโ in the mobile settings menu. It was set to 5G Auto previously.
I will just need to remember to set it back when I go home.
โ05-11-2024 21:26 PM
Did you update your APN setting, as advised here?
