IanFaulc_618833's avatar
IanFaulc_618833
i can not receive or make calls
  • Decembersangel's avatar
    Decembersangel
    Hi IanFaulc_618833 ðŸ‘‹
    If this is because of the 3G turn-off (which has happened recently and you are in the Midlands) then just search 'VoLTE' and you will see many, MANY posts with regards to this problem. It may be that your device isn't supported by SMARTY and if so you may have to change to a provider that does, unless you can afford to purchase a SMARTY supported phone to stay with them.
    https://help.smarty.co.uk/en/articles/8985136-checking-if-your-device-is-4g-volte-compatible
    If this is not the case then please add extra info so someone can help you further x
    IanFaulc_618833  I cannot help because of lack of information here.
