08-19-2024 03:13 PM
Will a voice and data sim work in a HUAWEI dongle for mobile WiFi? I have a data only sim that does, just wondering if I change my mobile phone to Smarty will a single voice and data sim work in both devices. I use the HUAWEI for occasional TV use when on holiday.
08-19-2024 04:10 PM
@PeterRo_2891713 I agree with @SmartyTrousers that it should be fine.
The only potential problem I see is the possibility of damaging it if you constantly need to move it between the devices.
A data only sim is effectively the same as a standard sim but it is simply provisioned so as not to deal with calls/texts.
08-19-2024 03:26 PM
Yes it will.
08-19-2024 04:10 PM
