05-16-2023 12:03 PM
05-16-2023 12:24 PM
Hello @Ninaj1974 . Normally, once you link your watch to the phone then you have the opportunity to answer calls on the watch or to make them from a keypad or call a contact that shows when you start the appropriate app. Put briefly, click on the phone app on the watch and go from there.
I admit that I am speaking about Apple products, but I would imagine it is similar process for Android products.
05-16-2023 01:19 PM
Thank you
05-16-2023 01:26 PM
@Ninaj1974 I cannot see why you would not be able to take the sim out of your phone and use it in your watch - if the watch can accept a SIM card itself. After all, you can take the sim out of one phone and use it in another (if it fits).
Try and see!
