Malcolm_1693198
19-03-2023SMARTY Rookie
Help
Phone is not working
1 Reply
- MSFSMARTY Guru20-03-2023
Are you showing an activated sim on your dashboard?
Have you tried the old tricks - turn phone off and then on again after a short while - take out sim and clean with gentle cloth and then re-insert.
If you have some further information, then more help may be available.
