05-04-2023 15:15 PM - last edited on 21-07-2023 13:00 PM by JodieB
How do I enter competition with having bought extra credit to do so and message not sending?? Help please
05-04-2023 15:21 PM
SMARTY don't currently support short-codes on their network, so you'd need to enter online. Most competitions usually have an online entry form @LauraWe_1311036.
05-04-2023 15:43 PM
As @Chalkychap says, you cannot send short code texts as Smarty does not support that currently. The extra credit has not been lost - you can choose to use it towards your next Smarty Plan.
05-04-2023 15:21 PM
05-04-2023 15:43 PM
06-04-2023 12:25 PM
I had same problem put £5 credit to send text didnt work but was able to use £5 to pay for monthly plan
06-04-2023 13:05 PM
Hi @AB . It's often handy to put some credit on the account when travelling to a non EU country for emergency use. Upon return, it's easy to allow the unused credit to be used towards the next Smarty plan.
