Get puk and pak codes
jaktalbot1
  •  I need a  puk  and  pak codes for my number
jaktalbot
@jaktalbot1 I see you have private messaged me about this as well. Like I said, you would need to chat to Smarty support about this. I don't work for Smarty, I'm just a customer.
13 REPLIES 13
RupertFr_749590
i need a  PUK code please
@RupertFr_749590  The answer is the same as it was on 16th June when you asked.
There is also anAccepted Solution and in addition I gave you a link to the help document with information. We can't do anything else for you I'm afraid.
RupertFr_749590
i've blocked my phone pls have puk no thanks
@RupertFr_749590  As the accepted Solution suggests, you need to web chat with Smarty Support. https://help.smarty.co.uk/en/articles/1159752-getting-and-using-a-puk-code
phoenix
After having screwed my PIN and no access to the phone I came across a 'chat bot' I entered my query in that and relatively quickly got an answer and some help by tech support - a few minutes later I was back to normal. 🙂 Well done Smarty.
Regards and many thanks
Bill
@phoenix It is SO refreshing to find somebody posting here with a bit of praise when they get good service. Glad it worked out well for you.
Some people seem to find it easier to whinge and gripe about everything but rarely acknowledge when things go well for them.
SmartyTrousers
@jaktalbot1 You can get a PAC by texting the word 'pac' to 65075.
I believe you'll need to start a chat with Smarty support for the PUK code.
You may wish to edit your post to remove your number, as everyone who browses this forum can currently see it.
I need a puk  I've no minutes texts and data lefted
jaktalbot
I need a puk for this?
jaktalbot
Where are the staff I need one
jaktalbot
@jaktalbot1  You contact Smarty Support via web chat.
how to access web chat
