Forward all calls to voicemail
IanJone_1765915
How can I redirect all calls to voicemail?
I know how to set up call forwarding to <number>, but have not been able to find out if there is a number I can use for voicemail.
Asking as I will be travelling to India and don't want to risk incoming call charges.
SmartyTrousers
@IanJone_1765915 The number is +447782333123.
SmartyTrousers
Thanks, I'll try that later.
The menus for call forwarding dont work for me at home (wifi calling) so will try the menus when I'm out. Otherwise I do know of the *# approach
Worked fine when away from wifi calling.
And the *# approach doesn't work on WiFi calling either.
