01-14-2024 07:44 PM
With a new Smarty account, I purchased a 2 GB data only SIM for £5. Worked fine in the UK then I travelled to France, where it continued to work great. When the 2 GB was down just below 1 GB, I purchased a 1GB add-on for £1. I did this while in France. There was a bit of delay before the add-on showed up (maybe an hour) but the service continued fine. The next day my original 2GB data ran out and showed zero in the dashboard. The add-on showed 1 GB as expected. However, the service stopped. The only site I could get to was smarty.co.uk.
A few more hours went by and the service started working again on its own.
I tried explaining this to the Smarty help chat (with a person). They said it should seamlessly change from the data plan to the add-on without any interruption.
As I will need to do this again next time I travel, I was wondering if anyone has seen this problem or has any thoughts on this?
Any help appreciated.
Thanks
John
01-15-2024 08:55 AM
@JohnRai_2438479 Certainly, the suggestion is that you should have been able to use the extra data - Price Guide p18 suggests that.
Could it simply have been that service was down on a local mast - or that you were travelling between two masts and lost service - or that you went from one network to another (that often happens abroad)?
04-02-2024 09:55 AM
same problem. If you let the data run out there is a definite time lag before the new data pack kicks in.
