27-10-2024 22:34 PM
My current data speed is 1Mbps. Is anyone facing the same issue in London? I am basically paying for nothing. I have checked the data speed in my house using other networks and I get 80 Mbps minimum. Is there any solution to this or should I move to another network asap?
28-10-2024 08:51 AM
@Nicholas Reply on your other post (it did not contain the same details ands you can ignore my point about your property shielding the signal).
