Options
- Mark as Read
- Printer Friendly Page
17-04-2024
13:45 PM
Your SMARTY SIM will not work abroad unless you make a one-off change to your phone settings. We’ve created a step-by-step guide to easily set up your phone to work for roaming.
[video]
If you're old school, we've also listed the written steps below:
Go to ‘Settings’
Open ‘Mobile Data’
Open ‘Mobile Data Network’
Change the Mobile Data and MMS APN to: mob.asm.net
That’s the only thing you have to change. If there’s any information in other fields, you can leave it as it is.
It should look like this:
Labels:
2 Comments
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
