- Mark as Read
- Printer Friendly Page
Your SMARTY SIM will not work abroad unless you make a one-off change to your phone settings. We’ve created a step-by-step guide to easily set up your phone to work for roaming. 🌎
If you're old school, we've also listed the written steps below:
Go to ‘Settings’
Tap ‘More…’ under ‘Wireless & Networks’ or 'Connections'
Open ‘Mobile Network’
Open ‘Access Point Names’ - If you don’t have any access point you’ll need to create a new one and skip to step number 7.
Open ‘3’
Open ‘Edit Access Point’
Change the APN to: mob.asm.net
If you find you can't change the APN, then you'll need to add a new one - you can find the settings here:
That’s the only thing you have to change. If there’s any information in other fields, you can leave it as it is.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
