Your SMARTY SIM will not work abroad unless you make a one-off change to your phone settings. We’ve created a step-by-step guide to easily set up your phone to work for roaming.
[video]
If you're old school, we've also listed the written steps below:
  1. Go to ‘Settings’
  2. Open ‘Mobile Data’
  3. Open ‘Mobile Data Network’
  4. Change the Mobile Data and MMS APN to: mob.asm.net
That’s the only thing you have to change. If there’s any information in other fields, you can leave it as it is.
It should look like this:
2 Comments
