WiFi Setting Turns itself Off
โ16-06-2025 14:06 PM
Since joining Smarty my WiFi setting turns itself off after going out of range of my WiFi in my house. I have created a new APN setting, as per the help, but it doesn't make any difference.
Has anyone else had this issue? I have a Samsung Galaxy S21 FE 5G running Android 15.
- Labels:
Network
โ18-06-2025 10:57 AM
The power saving was the culprit, WiFi hasn't been switched off since turning off power saving. Thanks to @MSF for your help.
โ16-06-2025 14:40 PM
@Christo_3418500 Surely, once you are out of range of your home wifi, the phone will move over to mobile data (assuming it is turned on)
Do you mean that the phone setting itself changes to off? An internet search suggests that it could be power saving mode, incorrect network settings, or even a software glitch.
โ16-06-2025 15:35 PM
Re: "Do you mean that the phone setting itself changes to off?"
yes, the WiFi setting changes itself to off.
โ16-06-2025 15:33 PM
Thanks for your reply MSF.
- yes mobile data is on.
- power saving was on, so I have switched it off to see if it makes a difference.
- the only thing I have changed since changing SIM cards are the APN settings. I did notice that my old SIM had quite a few entries under APN, but the help setup only mentions to configure the 1 setting named "3".
