03-05-2023 07:39 AM
Hi
When is there going to be a strong signal in Oxford?
Can only get 0.15Mb download speed so unable to do anything with it
03-05-2023 09:21 AM
Have you checked for any network faults or service issues in your area @Michael_1994897?
Do this online at https://www.three.co.uk/support/network_and_coverage/network_support.
03-05-2023 09:39 AM
Yes for some reason three/smarty sims do not work in Oxford area
03-05-2023 09:59 AM
@Michael_1994897 Even once you manage to discount any network issues in the area, it is possible to not receive a good signal due to interference from the building itself.
I suggest checking to see if the problem is the same all around the area and even outside the immediate area.
03-05-2023 10:04 AM
I live on a boat as continuous cruiser, last week near Bourne end I had 19Mb download speed so probably just this area with a problem, I have had a 3 sim and had to cancel contract after a week as no service here
03-05-2023 10:18 AM
Aha @Michael_1994897 !! Therein may lie the problem!! Smarty runs on a network which is.....wait for it!.......(drum roll).......3 network!!!!
If the 3 sim didn't work, then quite possible smarty won't work either - that's a shame!
03-05-2023 10:22 AM
Lol, yes will just have to use my sky sim until I can get a decent signal with the smarty sim it seems, thanks for advice though 👍
