โ03-31-2023 05:27 AM
Do I need to change the APN settings if I just want to use WIFI in The USA? I don't want to use my data allowance.
โ03-31-2023 09:20 AM - edited โ03-31-2023 09:21 AM
An APN change is only required if you want to use Mobile Data while roaming in the USA.
You can use Wi-Fi networks with Mobile Data turned OFF.
Without an add-on for your plan, you won't be able to make/receive calls, or send text messages if you're roaming outside the EU.
Have a good trip to the US @CareenL_1770108.
โ03-31-2023 03:40 PM
Thank you for clarifying this... I will only be accessing WiFi...
โ03-31-2023 09:48 AM
If you are just using local wifi connection, you only need to choose the relevant connection and enter any required password. There is no need to change any settings otherwise - it's a bit like signing on to your home network for the first time.
