Using WhatsApp abroad
ColinRimm_21502
@@Links to members
4 REPLIES 4
NigelTa_2127738
Any idea if smarty Data Sim will work India
@NigelTa_2127738  I have replied on your other post. Your current plan does not include roaming outside the EU and so you will need an add-on to pay for all use in India: https://cdn.smarty.co.uk/files/SMARTY-Price-Guide.pdf?_gl=1*1f6lfr0*_ga*MTcxMTQ2NjYwOS4xNzIyMjQxNTE2....
If your phone accepts an E-sim, that may prove a lot cheaper and you can use WhatsApp via the data on your E-sim plan.
@ColinRimm_21502 As WhatsApp relies on data, then you can use it when you have Data Roaming - free up to 12Gb in EU, charged elsewhere according to Price Guide.
JJP2RidesAgain
Yes, you can, but will need to change the APN in your device to “mob.asm.net” - Details of how to do this are this sub-section of the forum, the FAQ and the new help videos.
In the EU, you will have up to 12 GB of roaming data, depending on your plan.
Outside the EU, you will need to buy a data add on.
