28-04-2024 13:56 PM
Hello, I'm about to go on a driving tour of France that will involve a lot of Google Maps navigation and because I drive a very old car this will done on my Andoid phone. I've read a few posts about poor coverage in France but none very recently. Is there still a problem? Also do I need to change any settings or avise SMARTY of my plans?
Thanks
28-04-2024 14:42 PM
@PC4510 You need to read the article that was written expressly to help you:
https://community.smarty.co.uk/t5/faq/setting-up-your-android-device-to-work-abroad/ta-p/7919
28-04-2024 14:58 PM
Thanks I'll check that out
28-04-2024 16:47 PM
When you say “poor coverage in France” that of course depends on the coverage that will be provided by the French networks that you will be roaming on.
On your driving tour, it’s likely that you will get good coverage in major towns and cities, but maybe not in rural areas.
Depending on the plan you have, you have a roaming data allowable of 12 GB. Depending on the length of your tour, you may exhaust that, and need to buy a data add on to confine to receive data connectivity.
