Anthony_2359854
26-10-2023SMARTY Pioneer
Using a wifi dongle
I got the smarty sim to use in a wifi dongle while out and about in my truck. I just want the data. Im able to connect to the dongle but my iphone says ‘no internet.’ any ideas. I’m afraid I’m ...
- 27-10-2023
Anthony_2359854 You will need to make sure that the dongle has the correct settings to connect up. You will need to change the APN to mob.asm.net - that should be covered in the manual of on manufacturer's website.
27-10-2023SMARTY Guru
Liamwil_2713973
15-05-2024SMARTY Pioneer
Hi I have had the same issue and I’ve changed the apn settings and still it says no internet, I’ve now ordered a data only sim as the other had a phone number attributed to it.
do you think that this is the problem, so frustrating
