unable to receive and make calls
AlanSea_1914126
Just received email to say number has been transferred but unable to receive or make calls
As well as tips from @Chalkychap , check your dashboard to see if it shows the ported number.
Okay @AlanSea_1914126, a couple of things to try here:
  1. Turn OFF the phone with the SMARTY SIM - leave the phone OFF for at least 20 minutes, then try again.
  2. If that fails, do a Network Reset on your phone.
Good luck @AlanSea_1914126 ๐Ÿ€
