Smarty Sim in Samsung suddenly not making or receiving calls
@Michael_3103338 May be worth checking out this article: https://help.smarty.co.uk/en/articles/8985136-checking-if-your-device-is-4g-volte-compatible.
There seem to be issues with some phones not being compatible with the Smarty protocol for VoLTE.
Have you also checked the sim in another phone?
- Michael_310333814-01-2025SMARTY Pioneer
It's not listed as not compatible and I don't have another phone to check - we both use the same model. Mine seems to be working fine in the same model of phone. And anyway, why would it be working one minute and not the next?
- MSF15-01-2025SMARTY Guru
Michael_3103338 So are you saying that her sim works in your phone or not? If it does, then perhaps her phone is kaput; if it doesn't, perhaps the sim is kaput and you need to order a specific replacement sim via dashboard on account.
- Michael_310333815-01-2025SMARTY Pioneer
No, not saying that, as I haven't (and won't) try swapping sim cards around. Her phone, identical model to mine, Sim ordered about same time, intermittently stops working. One minute it is, next it isn't, so both sim and phone work, just not consistently. Swapping sims won't prove or disprove anything. Mine, so far, seems OK.
- SmartyTrousers14-01-2025SMARTY Centurion
Because Three - Smarty's parent network - have recently switched off 3G in most areas. Previously, phones which were not compatible with Smarty's VoLTE (4G calling) will have been switching down to 3G to make or receive calls. Now that most of that 3G coverage has gone, phones which are not compatible with Three's/Smarty's specific VoLTE configuration are going to struggle to make or receive calls.
