18-05-2023 20:28 PM
My daughter gave me her old iPhone 11 but it doesn’t seem to like my Smarty SIM. It says’ ‘the SIM you currently have installed in this phone is from a network provider that is not supported under the activation policy currently assigned by the activation server ….’ What can I do?
19-05-2023 08:46 AM
@Stephen_2022198 Sounds like the phone may be locked to a previous provider.
In that case, you would need to have it unlocked before using it with another network.You will need to approach that network first or else use one of the high street shops (check for a reliable one first).
It does sound odd - I thought that nobody bothered locking phones to networks these days, but probably I'm wrong.
19-05-2023 08:46 AM
08-06-2023 19:01 PM
Thats what I thought, yet Voxi say that phones bought from them are indeed network locked. I guess other networks may have the same policy.
@Stephen_2022198 Remember the iPhone 11 is "only" 4G capable, not 5G.
08-06-2023 18:27 PM
its says my sim is locked please call network provider buy smarty is my provider and have been for the lastd 3 years
09-06-2023 07:39 AM
@JosHoyte_507983 ....BUT....is the phone maybe locked?
