โ25-09-2024 14:25 PM
Ported over today, received confirmation its succeful now not receiving calls
โ25-09-2024 14:57 PM
@BrianFle_441327 Did you try turning off and then back on after a minute or two? This sometimes forces phone to correctly register to network.
Also, did you get a message telling you that the process is complete? Does the ported number show in your Account Dashboard?
โ25-09-2024 15:09 PM
Yep. Restarted and received notification that the number has ported over. Its showing as the right number in my account.
I must say though. The signal is appalling compared to 1p mobile
โ25-09-2024 16:17 PM
@BrianFle_441327 But all is working as it should, albeit signal level not as you hoped for?
Did you check coverage for your area and also network status?
โ25-09-2024 14:28 PM
Is your phone compatible with Smarty's 4G calling?
