19-07-2023 17:55 PM
Almost all the time there are difficulties and image distortions while watching a movie or listening to music. The quality and speed of data flow is not satisfactory. If that doesn't change, I'll change the operator.
19-07-2023 18:25 PM
I have replied on the other thread you started about this.
20-07-2023 11:20 AM
@Radosla_2063533 Unfortunately, this does sometimes happen, so changing networks may be the only option, but check carefully first and 3 network is likely to be similar as Smarty runs on it.
