Old number not transferred
GeoffKi_2202525
I canโ€™t use my sim as my old number has not been transferred
I contacted smarty and they said there was a problem, but how long will I have to wait, Iโ€™m still being charged for a months subscription but I canโ€™t use it
I been waiting 5 days for the number change ?
@GeoffKi_2202525 I replied on your other thread - the problem may be nothing to do with Smarty.
This is the Smarty community forum, populated by Smarty customers.
As we do not of course have access to your account, you would need to go back to Smarty to rectify whatever the problem may be.
Did you request a PAC code to transfer your number, or a STAC code, which terminates your old number ?
Even if you requested a PAC code, the number transfer may not happen until next week, depending on when you gave Smarty your PAC code, as number porting does not happen on weekends, only between Monday to Friday.
If you give your new network your PAC code between 09.00 - 17.00 on a weekday, your number will transfer within 1 or 2 business days. If you give your new network your PAC code after 17.00, you are deemed to have given them the PAC code the following working day. For example, give your new network your PAC code at 19.00 hours on a Friday evening, you are deemed to have given them the PAC code on a Monday.
Remember, numbers do not port at weekends, only during the working week, Monday to Friday.
PAC code : Porting Authority Code, which transfers your number between your old and new networks.
STAC Code : Service Termination Authority Code, which terminates your old number and gives you a brand new number on your new network.
