Not registered to a network??
JohnnyB_2580835
HELP PLEASE  am trying to set this mobile up ๐Ÿ˜ฅ
JJP2RidesAgain
This is the Smarty community forum, we are customers just like yourself.
To try to help, we would need some more info :
1, Have you activated a Smarty SIM card and bought a plan ?
2, Are you certain you have coverage on Three, Smartyโ€™s parent company, where you live, work and socialise ?
3, Is the phone you are trying to set up unlocked for use with any network ? If you are trying to use a 2G handset, it wonโ€™t work with Smarty, as it would need to be 3G at a minimum.
You can also contact support online at https://smarty.co.uk/contact
Customer advisors work 8am - 8pm daily
I have bought a plan and have Smarty SIM card and received email from Smarty confirming I am up and running. I was previously with Three so know that I have good coverage.
Are you sure you have inserted the correct SIM? I ask because SMARTY usually ship two SIM cards. Maybe you inserted the blank SIM that was intended for a friend.
