London underground wifi
J_332119
I can't connect to THREE_WIFI on the underground for the  past few weeks. It asks me for username and  password. I'm on iphone. I can't change the login to use AKA as there's no option for it.  please help
J_332119
I fixed it by iOS reset network settings!! Support was really not helpful
6 REPLIES 6
@J_332119 Did you see this article?: https://help.smarty.co.uk/en/articles/5830528-free-wi-fi-on-london-underground?_gl=1*1ecif42*_ga*OTk...
If you need to check the wifi settings on your phone, then you should not need any username or password.
J_332119
As I wrote  in my post I can't do step 3 of the article. I can't change the login to use AKA as there's no option for it.
@J_332119 In that case, I suggest a web chat with Support Team.
J_332119
They weren't able to help me.
@J_332119  Then that warrants a complaint. The Support Team...clue is in their name!
Management will hopefully pick up your complaint.
Sorry, but I cannot offer any other suggestions as I've never used that service.
J_332119
