Eu data plan
JohnWal_2915968
JohnWal_2915968
I know you can purchase a 3 day ‘add on’ data pass but I want a 14 day plan, I know 5 x 3 =15 but wonder if a cheaper package is available 👍
@JohnWal_2915968  To purchase 5 such EU Roaming data passes would cost £35 and would give you access to the rest of your data in excess of the standard allowance of 12Gb for EU Roaming.
If you check out the price guide, you will see that there is nothing else on offer:https://cdn.smarty.co.uk/files/SMARTY-Price-Guide.pdf?_gl=1*1ms5dr9*_ga*MjA5ODc3MzU1My4xNzI2MTM1Njc3....
A cheaper alternative for data may be to purchase an Esim, but it will depend upon how much data you intend using and in what country.
