Does anyone know if Smarty Network works ok in Tenerife? Especially UK Data Allowance
GordonF_2200904
@GordonF_2200904 I was able to use it perfectly earlier this year in a number of the Canary Islands.
Don't forget that roaming is limited to 12Gb data.
You can use your UK plan allowances in Canary Islands, @GordonF_2200904
The maximum roaming mobile data allowed is 12GB/month, or your plan data allowance if less than 12GB.
Jamie
Yes worked for me in Fuerteventura.
