Difference between £20 unlimited voice plan and £6 5GB data plan with unlimited voice minutes
ben1
Hi
I'm new to SMARTY and just getting my head round the different plans. Am I missing something here, what is the difference between the £20 unlimited voice plan, which has unlimited calls & texts and the £6 5GB data plan which also has unlimited calls & texts.
Why would anyone but the unlimited voice plan?
Thanks!
@ben1  The £20 plan has unlimited voice/texts PLUS unlimited DATA.
The £6 plan has unlimited voice/texts plus only 5Gb data - that's the difference - it is in the amount of data and all plans have unlimited calls/texts.
ben1
Thanks @MSF  - can't believe I didn't realise that, it's so obvious now you said it. Reading the plans fresh and it not saying anything about a data amount on that plan had me confused initially though!
Thanks!
