28-01-2025 13:01 PM - last edited on 30-01-2025 15:45 PM by JodieC
I'm getting a problem when phoning I get dialing... then nothing, if I dial again sometimes it connects sometimes it just drops out again. when I am unable to dial out other people cannot phone me. I am able to send and receive texts. The problem is intermittent.
Any help appreciated
30-01-2025 15:44 PM
Thank you for reaching out to our SMARTY Community Forum! I'm sorry to hear about your recent experience regarding calls.
Please refer to our network status checker to keep up to date with any outages in your area that may be affecting your connectivity and calls:
Network status checker | SMARTY
Let me know if this shows any outages as this is most likely the reason for failed or low quality calls.
I look forward to your response.
- Jodie
31-01-2025 06:23 AM
No outage in my area
30-01-2025 17:08 PM
@MichaelWh_99770 In addition to the advice from @JodieC , have you noticed whether your phone is showing a good signal when you try to make these calls? If only one or even no bars showing, the chances of connection are probably not great.
31-01-2025 06:25 AM
It was showing 5 bars. But is intermittent, I have tried from the same place Wednesday and got connected, I tried Thursday and nothing I get dialing... then call ended
31-01-2025 09:47 AM
I have had exactly the same problem for well over a month. Sometime it works fine, but more often the phone is completely silent when trying to make calls, and incoming calls go straight to voicemail (which I can’t listen to!). I always have decent signal.
