Data plan for home internet
Dibble
Hi, is there a limit to the number of devices that can tether on a data only plan? I'm considering replacing our house internet with the unlimited plan. Also is your NAT open or is it restricted?  We mainly use it on Xbox's and phones/laptops
JodieC
Hi @Dibble
Thank you for reaching out to our SMARTY community forum!
The number of devices depends on the device manufacturer, please contact or Google the device manufacturer to get a specific number of devices that can connect at the same time.
I hope this helps!
- Jodie
@Dibble  In addition to what @JodieC  says, don't forget that mobile data is not a substitute for home broadband as it is often not as reliable and does not have any speed guarantee (unlike broadband)
JodieC
Hi @Dibble
I hope this helps!
- Jodie
