02-20-2024 09:15 AM
Is anyone using the a TP-Link VR100 AC2100 MODEM using ZTZ 4G DONGLE wth SMARTY? If so did you have to enter any settings & what were the settings please?
02-20-2024 10:28 AM
@ROBBURR_2549987 I will start by saying that I do not use that device. However, for any device that connects to Smarty data, you need to change the APN to mob.asm.net. Usually you can do that by putting 192.168.1.1 into the url bar of a browser and it should take you to the router 'home page'
02-20-2024 01:02 PM
Online, various SMARTY support articles seem to imply if you're staying in the UK, and not roaming abroad, APN settings don't need changing. That said, data also works when using the APN "mob.asm.net" value in the UK.
