Can't call 0901 numbers.
Christo_2934468
I can't call 0901 numbers to vote in eurovision. At this point I'm beginning to wonder if there are any **bleep** numbers I can call on this wretched network.
What's the point of this top up crap if it can't be used for anything?
Decembersangel
Hi @Christo_2934468
With a SMARTY SIM, you cannot call 0901 numbers as part of your plan. 0901 numbers are premium-rate numbers, and SMARTY plans do not include calls to such numbers. These numbers are typically associated with chargeable services or entertainment.
Premium numbers:
Calls to numbers starting with 09, 070, 084, or 087 are not included in the plan and will be charged.
Add-ons:
To call premium numbers, you may need to apply a chargeable add-on to your SMARTY account.
h t t p s://help.smarty.co.uk/en/articles/3988852-out-of-plan-add-ons
(remove the spaces between the h t t p s)
Hope this helps x
Unfortunately it doesn't help - I'd already added the chargeable add on and it didn't work.
@Christo_2934468 0901 numbers do not appear in the Smarty Price Guide which indicates that they are not available.
