10-11-2024 12:00 PM
Hi,
When I get an incoming call, my (Android) phone used to announce the name of the person calling.
Since switching to Smarty Mobile this no longer happens. Is there something I need to do or is this feature not supported by Smarty??
Thanks😊
10-11-2024 04:47 PM
Ok, so it sounds like there's no issue at Smarty's end.
I'm wondering if that setting gets reset when you insert a new SIM into your phone. Here's some instructions I found for how to enable it if you use Google's dialer app.. obviously the steps may be a bit different if you use a different dialer app.
10-11-2024 01:06 PM
Can you see the caller ID (phone number or name) of the person who is calling you?
10-11-2024 02:05 PM
Yes, but no announcement ...
10-11-2024 04:47 PM
10-11-2024 10:16 PM
Yep, that's done it! Many thanks - it seems I'd enabled caller announcement in the Samsung dialer App but not the Google one - as you say, seems the setting got reset. Cheers 👍
