24-08-2024 14:45 PM
Does Smarty support call forwarding, and what are the costs?
24-08-2024 17:35 PM
Yes it does. It doesn't cost anything, assuming you're forwarding to a number which is included in your package (i.e. a standard UK landline or mobile number).
24-08-2024 18:35 PM
Thanks very much @SmartyTrousers 😃
24-08-2024 17:33 PM
@threepennys There is a helpful document: https://help.smarty.co.uk/en/articles/1463317-setting-up-call-forwarding
As far as I'm aware, there is no charge as it involves calls to UK land or mobile which is included in the plan.
(Anyone else please feel free to advise otherwise if I'm wrong!)
11-05-2025 16:03 PM
This list is not correct (I just tried it out as I'm going away) 😞
24-08-2024 18:35 PM
Thanks @MSF for the helpful info 👍
